box size?
r those the internal diminsions? if so, they work out to 1.7. depending on sub displacement, it'll get you close to the 1.5. if they are the outside, how thick of wood are u using? that'll change the answer.
cu ft= L x W x H / 1728
Originally posted by mrray13 r those the internal diminsions? if so, they work out to 1.7. depending on sub displacement, it'll get you close to the 1.5. if they are the outside, how thick of wood are u using? that'll change the answer.
Yeah I'm an idiot...I divided it by 1128 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif..hey 3/4 aint bad, but not good:(
- Steve
Originally posted by ss3079 Yeah I'm an idiot...I divided it by 1128 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif..hey 3/4 aint bad, but not good:(
- Steve
it's all good, i mean u r from canada, so it's to be expected!!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D lmao
Originally posted by mrray13 it's all good, i mean u r from canada, so it's to be expected!!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D lmao
Hey hey hey, now, lets not get into that lol..Project "Boom For the Buck" needs to get underway!!//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
- Steve
Originally posted by ss3079 Hey hey hey, now, lets not get into that lol..Project "Boom For the Buck" needs to get underway!!//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
- Steve
and with your mad math skills??//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif :eek: sh!t, ur done!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
seriously, u decided what ur doing with the "pro"ject?
Originally posted by mrray13 and with your mad math skills??//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif :eek: sh!t, ur done!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
No....I want to decide...but want to do it right the first time, so research is key. Probably looking at Shocker or RE...but still open to suggestions. Have like just over 8 cu. ft. to work with.
- Steve
thanks for the feedback.those were internal dimensions and using 3/4 inch.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Try the sealed then. If you feel you're lacking low end extension you might try to build a ported box to give you a little more output down low.
jackson
jackson
Huntsville,AL
jackson
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
