Box Size Question
Blackout04V
I'm curious to know what the differences between, for example, a box that's .85 cubic feet as opposed to one that's 1.0 cubic ft. Like does one make it hit cleaner or make it 'louder'. The recomended size for a sealed box on the Type R is .7-1.0. I'm not looking for all out tuned sound here. Just to know which one I should be looking at purchasing. I've tried searching but I only find info on specific box sizes for certain subs. Like maybe one size makes it tighter bass while the other gives more boom or thump.
I recently purchased a 12" Alpine Type R dual 4ohm. I'll be running either a 550 watt Alpine amp or a 600 watt Kicker. It'll be run by an Alpine head unit and it'll be in an '04 Nissan SE-R Spec V. This is why I'm curious to know what box I should purchase. Thanks for the noob help.
Build you own box, its really easy, custom boxes look much better and sound so much bettter
Bigger boxes usually mean:
1) sub can handle less power than usual
2) The sub plays lower frequencies easier
3) *usually* more SPL
I would probably put that Type R in a bigger than 1 cube I would probably put it in a 1.5ft^3 like he did
Either way you go, WATCH THE GAINS!
Over powering usually doesn't kill speakers, people kill speakers (aka CLIPPING!) most of the time. People want to run 600Watts and turn the gains more than 3/4 way up and then have the bass remote turned up to MAX, thats a good way to blow the speaker //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif So in the end they are sending 600+watts that are sending HORRIBLY DISTORTED SINE waves to the driver, in the end blowing the coils
Blackout04V
Blackout04V
Chicago
Blackout04V
NorthFramingham
    Jun 30, 2026
