Box size for an 18
burro breath
Ok so I built a box and installed it in my car and the sub moves way too much off of the 150 watts I'm sending it. The Box is about 5 cu ft sealed. The woofer is a custome recone I got from teampsi. Is my box to big for. Sealed setup ? And if so what shop the box size be?
on the team psi 18, try 5 cubes ported to 32hz with 80sq" of port.
I doubt the teampsi sub will do well sealed (bl, btl, sx, mt are all like this)
unless you specifically had it built that way.
The box has a slanted back and 1 slanted side. So it's an odd shape. It's so big that I had to assemble the box in the trunk because it wouldn't fit through the trunk opening. Now because the box is a wierd shape does this mean I can't port It because I am gunna have a hard time putting a baffle in. But can I use some adjustable aeroports?
If it's sealed and you were looking for lows a big box that's effecient is a good thing. How loud your sub will get down low is just depends how far the cone moves whether it takes 100 watts or 1000 watts.
burro breath
burro breath
connecticut
WrenchGuy
