Box question?
  • 6
I'm a ported enclosure fan, you get more output from the sub most of the time "sub dependent" , with a ported enclosure then with a sealed. and more lower end frequency response as well. and you don't need as much power to push them.
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
Yeah I'm in a circle right now too. I'm going to use 3/4" birch so I don't want to build it twice, stuff ain't cheap.
Emphasis added. The answer is, because you can also see DCR at other frequencies and because low impedance is extremely torturous on...
Common chambered sealed or ported is fine. Just make sure you have sufficient bracing
Chevy Boy
Chevy Boy
Greenville, NC
PowerNaudio
