did yur friend already buy the woofers? If not jus throw a single 10 inch 187 in ityah it really is , But the space we had to work with sucked :/
haha jus tell your friend stfu im doing what i wantA little? That should have just been a sealed enclosure. Fuck what your friend wants. They don't know whats good for them.
x2Actually you can still use both 12" drivers. Just Isobarically load them instead.
Why wouldn't he. It isn't adding any more volume to what she has made. Isobaric loading allows you to use HALF the volume you would use on ONE driver. It also gives great linearity and helps negate any anomolies between 2 drives. The only downfall is it is not as efficient and will be 3db quiter than 2 drivers in their own space with the same power.If he has room for that..
Right... But he might not have space to have a driver inverted like that.Why wouldn't he. It isn't adding any more volume to what she has made. Isobaric loading allows you to use HALF the volume you would use on ONE driver. It also gives great linearity and helps negate any anomolies between 2 drives. The only downfall is it is not as efficient and will be 3db quiter than 2 drivers in their own space with the same power.
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gifhaha Thanks for the replys, yah 20 Deep would have been alot better than 15
