Box i built sounds like da fudge
skylineTT
bass=sekz
Well I built a box using RE box calc as always (they usually turn out sounding alright) and to achieve the tune I wanted, it called for a 28" port length in the back.. well the box wasnt wide enough for that so I took length off of the end of the port and glued it to the wall with the port width being the distance from the port to the wall.. you can see from the pics.. anyways, I figured that the port length would still be the same but just in a diff configuration and area was the same so tuning shouldnt suffer. well it did! seems to be tuned much higher than I aimed. I also used an FI X in the box which needs about .5 cubes more than what the box offers (didn't know at the time). anybody see any design flaws in the box or is it just that the sub wants a higher freq? thanks
Calculated box. you can see the port is too long so i cut the end and placed it forward
built box
18" of port area btw
Was it a 12inch speaker that was used? If so that box is too small, needs 45s in the corners and by adding the 2nd port wall that comes in from the side, that ate into your airspace and lowered it even more.
Dont use the RE box calc, it is very inaccurate
well the box is made out of .75, measures 24 wide, 13.5 high, and 12 deep with 1.5" port width. it is supposedly 1.2 cubes at 30hz but it doesn't play like it is. the sub displacement would subtract from that a little too, and the way i configured the port might have stolen some area from that unless the box calc factored that in.
haha it is an FI X i had laying around. the wood was also laying around so i didnt design it for any specific speaker. it was the biggest and lowest tuned box i could build with the little amount of wood I had. all of them were 12" by 8ft strips too.
Well I'm not the greatest at slot port calculation but heres what I came up with
24x12x13.5 overall dimensions = 2835cubic inches
subtract port displacement of 1080 cubic inches
leaves you with 1755cubic inches divide by 1728 = 1.0156 cu/ft
figure around .1cu/ft for sub displacement so about .9cu/ft
total port length is 42.25inches, combined with the port area and volume comes out to about 34.3hz tune
Definitely looks longer than a 40-42" port in there.....just from looking at it. The extra board decreased your net volume (took up space) so that raised the tuning a lot higher than your port calculation.
Use WinISD if you want a better calculator. I'm sure there's better ones out there, but this is what I use in a pinch. I just take the calc for a rectangle port and adapt it for use as an L-port.
LinearTeam
skylineTT
bass=sekz
skylineTT
Houston/Dallas
skylineTT
