box help
  • 4
kwitcherbichin
i got a 7 cf box with 4 orion xtr pro subs and i need a lil help
but anyways if possible i would like someone to try to help me redesign this box to perform better
max dems are 18 tall 23 deep and 36 wide. i would like the box tuned around 25-28 hz im sure it would be a close call on the size and displacement of the subs with that low of tuning but if possible just let me know my options.
i want this enclosure to move alot of air with low notes. or at least perform greatly with low notes.
ex. one of my older systems
18"x23"x36" is only 5.03ft^3 before sub and port displacements...it's a tight fit for a pair of 12's in that space, not to mention with a 28hz tuning it'll be pretty much impossible.
I didn't even do the math..LOL
Edit just did that math it is 7.08ft3 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Still to small though
18 is 16.5
36 is 34.5
23 is 21.5
multiply
12,238.875
divide by 1728
7.08
what kind of calculator are u using... its barely under 7cf with just the sub displacement... how big was the port u were gona use?
Sorry, I must have mis-typed something into the box volume calc I was using...did it again and you're right at 7.08ft^3. If you're wanting to tune that low with adequate port area you're really going to eat up some box volume with a ~35" long port. Even doing three of the subs in that size box is a stretch, you'll either have to sacrifice box volume or port size...
900
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
610
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
kwitcherbichin
kwitcherbichin
stantonsburg, nc
RAM_Designs
slater
    May 2, 2024
slater
    May 2, 2024
