Box help
yeah i can fit it i was just wondering which enclosure size to go with my friend told me if i go with 1.75ft^3 that i wont get the lows and he told me that if i go with the 2.25ft^3 then i will get the lows. so he told me to just go with the number in between and i wanted to make sure what to do.
If using a shared chamber box, yes, since you don't need as much air space per sub to get the same result as using larger, individual chambers for each sub. Using a shared chamber allows you to slightly cut down on box size. Stick with a 30-32hz tuning for good low-end.
eric78702
eric78702
Austin, TX
eric78702
