Box help!! hdc3 12
jersyn82
I am new to this and I can't seem to get all my figures right. I am trying to build a box for a single 12 in. Hdc3 for a 4 door car.
I want to run it at 35-36 hz range from what I hear. I have found plans on different forums but none I can really use.
My maximum width is 34 in. Height is 14.5 maximum and depth 17. I also want to run bracing probably just 1 in. dowels.
Anyone's help would be greatly appreciated!!
You could do 32w x 14.5h x 17d with a 13h x 3.5w port 31" long for 2.45@36.13hz with 18.5sqin of port area. I can make you a cutsheet and sketchup when I get home if you want it. Did one similar for a guy and it turned out awesome.
Sent from my G870a on 38's.
Make sure you add a double baffle in the cutsheet.
you'd want to use the max width man, need double baffle and room for bracing/45s.
3.25 port width is more than enough tuned to 35hz. With hdc3s shoot for 16-17 port per cube, 18 begins to lose bandwidth.
http://www.stevemeadedesigns.com/board/topic/187809-hdc3-hdc4-optimum-enclosure-size/
jersyn82
jersyn82
ohio
Jeffdachef
