Box for 4 L7s complete....
Its a hell of a lot closer than settin it by hear bro, an o-scope is the most accurate way but as long as you take it easy on the gain and set it properly you will be fine. If you keep blastin the gain and causing that light to come on your gonna end up frying your amp or clipping your subs to death. Read up the gain setting tutorial and you'll be fine.
My gain is on 1/4 or so right now.. My subs are wiring by each sub having a + and - from voice coils 1 and 2 connected by wire. Then, all +'s are connected and all -'s are connected and from the last subwoofer, a + and - goes to my speaker terminal. The speaker terminal has 1 + and 1 - go to the amps + and - (bridged). So total it's a 2 ohm load since they are all dual 4 ohm.
Alright cool thats how it should be, btw its not bridged since thats a mono-block, it doenst matter which set of terminals its wired to, they just put in another set for ease of wiring. But everything is good there, so just read the gain setting tutorial and set your gain with a dmm and youll be fine bro.
dmm?
turn the gain all the way up if you want to get full power out of your amp
You bad //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Trying to make his amp blow up //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Yeah man, really close to there. I live in Kingswood, it's off grey road in between 106th and 116th. I'm like a couple minutes away. Maybe you could help me with my amplifier issues.
xpl0it
xpl0it
everywhere
xpl0it
