Box for 3 9kv.2 subs?
AK SloPok
I am looking for some assistance with a box for my 9.kv.2 subs. I used to run 6 of these in a sealed box in my PU but now I have an SUV and have to rebuild my system. I want something small enough that doesn't take up too much space but I would also like to try porting. Should I just go with the RE box calculator or can someone come up with something sweet I should try instead?
Specs: Qts: .30
Qes: .38
Qms: 3.5
Fs: 23 Hz
Re: 7.4
Vas: 45 L
Mms: 71.4 g
Bl: 15.34 T*m
SPL: 86.2 dB
Sd: 231 cm^2
Xmax: 14.1 mm
Voice Coil: 38 mm
Magnet Width: 4.800"
Cutout Diameter: 7.25"
Mounting Depth: 4.375"
Weight: 10 lb
Total Height: 4.900"
Displacement: .05 ft^3
Outside Diameter: 8.375"
Recomended boxes:
Box Size Suggestions Outline
Spec
9Kv.2 Subwoofer
Sealed ( small )
0.2cF
Sealed ( ideal )
.35cF
Sealed ( large )
0.5cF
Vented ( ideal )
0.5cF Tuned to 30Hz
Vented ( DDLoud)
0.7cF Tuned to 35Hz
These were obviously taken from ED's site...
I plan on running about 600 watts rms to the three speakers. The largest I want to go is around 12" high, 48" wide, 12" deep These can be changed a bit but smaller is better. Thanks in advance...
Chad
AK SloPok
AK SloPok
Anchorage, AK
AK SloPok
michigan born
    May 14, 2026
michigan born
    May 14, 2026
