Port length and size..I **** at this.
Zxcvtypo
My box is going to be 30x20x17, sub firing up, aero ports (or tube, i dunno if aero is the actual name for them) on the bottom back of the box firing towards the back of the hatch...I'll prolly be ordering them off partsexpress, but I'm completely lost as to what diameter and length I should get for a tuning of 30hz? I'd like to have one on each bottom corner of the box..or just a big one in the middle? I have no idea what would work best..Any help would be appreciated, thanks!
No, each port is 26".
As your port volume increases, so does its length.
each port 26"? umm are you sure about that? what Zxcvtypo said about using 8" diameter and dividing the final port length by 2 makes sense.
No, his way is completely wrong and illogical. First off, two 4 inch diameter ports are no where near the surface area of a single 8 inch diameter port.
Also, the more port area you have, the longer the port becomes. If you add more ports, you add more port surface area which means you need to increase the length. Adding all the lengths together does NOT give you the total port length.
Zxcvtypo
Zxcvtypo
Frederick, MD
Zxcvtypo
