Box design issues, HELP!
ZO6killinsbf
Beer is good
Ok, I followed the tutorial and I thought all was going good until I checked the transfer function magnitude in WinISD.
(2) Infinity Reference 1262w's
Power Handling, RMS 300 W
Frequency Response 23Hz - 400Hz
Nominal Impedance 2 or 8 Ohms
Sensitivity (2.83V @1m) 96 dB
Mounting Cutout Diameter (Metric, English) 11-1/8" (282mm)
Mounting Depth (Metric, English) 6-7/16" (314mm)
Vas (liters) 80.14
Fs (Hz) 25
Qts 0.46
Xmax (millimeters) 13
Single square/rectangular port box, 4 ft/3 tuned for 34 Hz
3/4" MDF 45 x 16 x 16.5
Inner dimensions: 43.5 x 14.5 x 14
Port dimensions: 14.5 x 4.13 x 30.51 = 1805.5 in/3
When I run the numbers it comes up with a peak @ 168Hz!! What did I do wrong or skip? Bad math? Please help.
Also, I'd like to do the numbers for a center port if at all possible. Thanks
Be sure all of your entered values are correct. The first time I tried designing a box, WinISD said it'd be tuned at 81 hz. I later found out that I mis-entered one of my port dimensions.
This?
ZO6killinsbf
Beer is good
ZO6killinsbf
McKinney, TX
ZO6killinsbf
