Box design help for single 15" FiQ
Box outside dimensions.
use .75 mdf
D x W x H
20 x 24 x 18
Two 4" outside flare ports 15.3" deep.
remember the flare portion is actually counted
as half it's actual legnth. Mount the ports
along the bottom of the box 1 on each side of
the woofer; on the same side as the woofer.
Aim the box backwards try to give it 6-9" before
the sound hits the back wall. Then experiment with
the box closer/farther or pointed up. Once placed,
screw the box down with an L bracket.
3.56 cu^ft net after port(s) and woofer displacement.
32Hz tune.
3.97 cubes gross.
Credit someone else on the forum for this pic of port flare
calculation
the d300hc is going to run at 1ohm for the time being until I get the sub reconed so I can run it at 2 ohm. Although the mmats is 2ohm stable they can be ran 1ohm. They have a protection circuit built into them that I guess limits the voltage so they don't fry.
I thinks you need to add a little more depth to the box to use a 17" straight tube.
The air intake is too close to the back wall (2").
Let me recalculate.
Freelander
Freelander
Jacksonville. FL
mcsoul
