Box Design for orion hcca 15.2
BAPEKC
2LT
Hey CA,
I need a box design for my car.
I have a 2000 Volkswagen jetta.
Trunk space available is 25" x 36" x 17" (L,W,H)
Subwoofer is a orion hcca 15.2
Amplifier is a skar 4500.1 on stock electrical no batteries.
I would like a vented enclosure into the cabin.Im going to have the port facing forward and seal around the enclosure. A low tuned box would be great (29 - 32 hz) . I play all kinds of music.
Ideally you can use all space available I don't need a trunk lol.
Thanks All.
Lol not to be rude but with your VERY sad electrical I wouldbt even attempt to install your equipment expect to ruin your alt. Or your equipment.
And as far as box very large and ported at about 34 hertz probably
Not sure that sub will handle 4.5kw either....although if you don't upgrade your electrical it would be impossible for that amp to produce 4.5kw anyway so it may not be a problem //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
EXACTLY reason im not worried about electrical as of now.
Original point still stands though, I wouldn't try to get more than 1kw out of that amp (i.e. set the gain properly for 1kw output, don't guess) without upgrading the electrical. You will burn up your alternator otherwise...
im shopping now for a alt also I haven't began anything as yet so ill take your advice...thanks
BAPEKC
2LT
BAPEKC
NYC
BAPEKC
