Box Design For My Sub......suggestions Needed
muzik
i picked up a crunch amp and a soundstream pcw-12 for my explorer. reason being i only buy 1 sub is im just looking for some nice clean bass to add to my 4 new infinity door speakers and to save space in my truck. i used to be into car audio big time in late 90's early 2000's here in vegas, all competition db drag with fosgate so i know a little but not much about box building design and knowing how to build a tuned box for your sub, being able to capture the best possible performance is what im looking to do with this 1 sub. i listen to mostly rock and on occasions some r&b/pop/rap if im rolling with my girl .
the recommended box design says sealed @ 1.25-3 cu.ft.
how big(cu ft)would the box be if i wanted it a ported box or bandpass?
which box design sound better for my application?
looking for some educated guidence here, so i appreciate all suggestions. oo and BTY im a carpenter so nothing is to crazy or out of my capabilities to build!
Thanks guys,
Lukas
Amp spec. Crunch P1100.2
RMS Power Range : 225-550 Watts
Number Of Channels: 2
Maximum Power: 1100 Watts
Built In Crossovers: Yes
Channel Separation: Yes
1/2 Channel operation
RMS Power @ 4 Ohm: 1100W x 1
RMS Power @ 2 Ohm: 550W x 2
RMS Power @ 4 Ohm: 225W x 2
Bridgeable amplifier topography
MOSFET outputs
Illuminated Crunch logo
PWM digital power supply
High-level inputs for OEM radios
Fully adjustable crossovers, Hi-Pass and Low-Pass.
Silver RCA line inputs & outputs - permit amplifier daisy-chaining
Silver power connections
Sub specs pcw-12 soundstream
Sensitivity: 89 dB
RMS Power Range : 350 Watts
Peak Power Handling: 700 Watts
Impedance: Dual 4 Ohm
Low Frequency response: 25 Hz
High Frequency Response: 1100 Hz
Diameter: 12 Inch
Voice coil Diameter: 2"
Magnet Wgt. (oz): 50
Frequency response: 25-1.1kHz
SPL: 89dB
Woofer depth: 5.0"
Recommended enclosure: 1.25/3.0
Recommended enclosure type: sealed
Voice coil woven tinsel leads
Vented and extended pole piece
Low carbon top and bottom plate
Rubber magnet cover
Stainless steel stamped basket
UDV cooling technology
Low resonance woven carbon fiber cone
Black progressive roll conex spider
C-lock rubber gasket
Hi-arc high excursion surround
muzik
muzik
las vegas
muzik
