Box design for 3 15 SE's
I need a design with a bottom port, not an L port, to maximize the area on the top baffle for the 3 15's.
like this
design would be greatly appreciated, thanks
needs to be at least 10 cubes net, i could do a full 4 cubes per each 15, but a 12 cube net box is kinda big and i want to save vertical space.
at 32 to 33 hz
u need to coat the sono tube with resin ... while the resin is wet is a good time to bond the tube to the box then u can run a bead of epoxy around it for extra sercurity
Cravingbass123
Soda941, FL gulfside reppin
mobeious
