Box Building Comp-
Originally posted by crakerhead which ever one can w/stand most power
but then we're going to have to set a maximum thickness, otherwise people will just use 5in+ of mdf. maybe an in. max, then we can set dimension requirements(like 32x15x15), and volume. i say internal volume only because you could be using up like 4cu. ft. in bracing. but sounds like a fun idea.
Originally posted by dbhittin We Should Have one. There would be rules and then we vote who gets to try the best box out, and take it to comps or show. I was thinking like must use mdf, no fiberglass. Let me know what u all think
I figure I can make a pretty solid box... only problem is, takes too much time for me to make one...kind of a perfectionist when it comes to building boxes...doesn't mean my boxes are perfect, not pretty..lol, I just try the best that I can manage.. spent 2 weeks making my first box...always giving it a minimum of 24hours for glue/silicone to set.
hmm, don't you think if anyone who's had previous experience building boxes be4, makes a box using 1"MDF with precut wood, most boxes are gonna withstand even a pair of DD's on a full load?
Must be some other way... unless you give about 2~3 hours to build the box...then most of them might break apart with a pyramid...//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif woodglue won't even dry then...
Originally posted by Moocow16 alright then, i was just saying to make a thickness requirement, maybe not an inch then, half an inch?
recommended thickness is at an average of 3/4"...
some boxes are made of 5/8" MDF though...older ones...
and at 1/2", maybe HDF might be able to withstand it, although I'm not sure at all of this fact... jmac told me before that HDF has quite a lot of disadvantages...
i say maybe make a box using gypsum board,,,:p THEN box building techniques will REALLY come into play...no brace, no play...imagine the flex on that thing...should have an xmax of its own...//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh:
dbhittin
Banned
dbhittin
Van...Wa
Moocow16
