Box Build for Klepto [Pics]
ssj2xxgotenxx
The Chan Man
The box design is acredited to Moe Lester once agian, and the exact specs is 2.25 CuFt @ 32hz. Features include rounds port corners, rabbited edges for carpeting, and window bracing. Will be constructed with 1.5" drywall screws, Titebond II, GE Silicon/caulk, springload terminals and carpet compliments to partsexpress.com, and 3M spray adhesive. Box is design for a Stereo Integrity Magnum D2. Enjoy.
Supplies
Pile of wood
Window Brace
Side panel w/rabbited edge
Rounded portwall
Test fit with 12" XXX use the same 12 spoke basket I assume.
Stacking wood to test fitment
My mag is gonna have a very nice home soon. Thanks Jason. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Why do you always **** with moe lesters designs? And move the sub closer to the port opening? //content.invisioncic.com/y282845/emoticons/dont.gif.ed5870f9483b695f9745036963f41c24.gif :dont:
Does it really matter where the cutout hole is located in comparision to the port for that kind of box?
What will change?
I know plenty of poeple that have their sub in that location, and none of them have had any problems, including myself. I move them so I can incorporate a brace.
hey... while you've got your roundover bit out, do roundovers on the inside edges of the square brace //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
less turbulence = more deebeeeeeees
Well, obviously the brace wasn't there before.So it must not have been needed, or don't you think he'd put it in? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
x2 Box is on the small side, and would have been fine without the brace.
That single sounded edge wont do much man, why did you choose to only round that edge? It looks allright though, for the most part. Although, I dont think the work is good enough to sell:crap:
the main things i take issue with (appearance-wise) are the woofer and brace cutouts, but i see your point about the single rounded edge... if he's trying to reduce turbulence he needs to roundover the outside of the port, the inner corner of the port's turn, the brace cutout, and use a section of PVC pipe + resin to round the outer corner of the port's turn.
ssj2xxgotenxx
The Chan Man
ssj2xxgotenxx
Bay Area
klepto
