Box build for HATCHET_WARRIOR
SPY
NY
1.25 ft^3 tuned to 34hz for one OZ ME10
Design
Covered in black carpet, the red part is paint.
Double baffle, flush mounted.
Doesn't look like much yet, waiting for the Aero to arrive.
I can't really do any more work until the aero gets here on Monday.
OK, I finally got some more work done on the box.
There was a small change in the design, we decided to make the red part raised up.
Layout for the raised part.
Test fitting the raised pannel.
Flushed in the Aero.
Holes cut in the pannel.
Holes cut in both baffles
Another shot.
More to come later //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Updates....
Both baffles are mounted
We decided to add an amprack to the top of the enclosure. I forget exactly which amp it is but it will be flush mounted on the top of the box.
Updated design.
Amp rack added.
OK, I got a little more done.
Rounded over the edge of the trim piece 1/8", just enough to take the edge off.
and cut the hole for the speaker terminal.
The tricky bit is that they're soft and floppy and they may be stretched a tad to go over the frames. I've used them in the past and come out...
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
Love this sub, hate AB's site, short on info for sure. American Bass XR-10D2 box recomend: If you want to tune a 2.75 Cu Ft box (for two of these...
SPY
SPY
NY
BASS_WARRIOR
    May 16, 2024
    May 16, 2024
