OP
knowledgestick
- Thread Starter
- #91
i have no idea why you decide to attack me when i have made it clear i know nothing about car audio and it was futurehsop that handled this hole installation, the first subwoofer i put it in my self i mearly copyed their wiring from the last subs i had that where d4, then when they put them in they said they where at 2ohms each so w/e.Yes, in series... //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
OP I'm sorry but you completely FAIL at car audio.
Some of you guys might think an amp setting caused this.. but I doubt it.. even with gain and bass boost maxed and that amp clipping hard it shouldn't take those subs out.. and if it did I'd expect to see a damaged coil, not a cracked dust cap..
If you are going to blame the box it should be because the box is way too small.. not necasarilly because it's sealed.. the increased Q of such a small box will certainly put more pressure on the cap - but it still shouldn't have cracked... that coupled with the fact that the other cap looks like it started to melt tells me that RE should be using caps that are much thicker...
I don't want to hate on parts from china, just really cheap parts from china and dust caps that belong on a 250watt woofer, not a 1000 watt one...
Also i just spoke with a guy named mark from RE audio hes sending me 3 dustcaps and the glue to fix them with, he is sure that futureshop dropped somthing on them to start the crack so i dont know what to think now.
He said it was just gross incompetence for them not to adjust the gain accordingly to the new subwoofers, aswell as the box being sealed, plus probably somthing being dropped on them but he cant be sure but he is sure of the above 2 as i told him about them saying sealed would be fine, and that they never touched the gain settings to propperly adjust for the new subwoofers
