well i just tested them again, and they got hot at the center of the dust cap and i figured if they where that hot at the cap the drivers must be extremely hot, so i reached down into the vented box and to my suprise the drivers wernt all that warm even up into the center where i could reach with my fingures.
i dont get why the things are heating up and stinking so bad, the box may not be to spec but its still a big *** box, and has alot of port for breathing.
Are R-E audio subwoofers really that finicy ? it says in their manuals they are built for brutality and that they build there gear for "real world use"
it would seem they require some serious pampering if it is due to the box being a couple cubic feet too small.
I have fiddled with the gain, and put that to 12'oclock and had it a little past 12 o'clock, and the system is not that loud at all.
The system doesnt really seem to get loud unless the level is turned to where i had it in the video.
And even if it is turned down less, they still heat up and get stinky it just takes a little longer..
anyways, what would you guys sugest ? should i take them out of the trunk and have a hole new box rebuilt that uses up basicly every square inch of my trunk for airspace or what ?
i did not think that thease things would be such a hastle after dealing with MA audio and their woofers suposedly being "tough as hell" i figured thease SX's would be perfect and wouldnt cause any problems, i was wrong.
I hope i can get this resolved and fixed.
