Bose system- Head unit swap
atldavek
GA
I was wondering if you can do a headunit swap without replacing the factory speaker/amp. I know that the Bose is all 2Ohm drivers so they can't be ran to a new headunit, but is there a wiring harness for this that maybe runs the signal to the Bose amp?
This is a 1998 GMC ENVOY that has seemingly 1 Bose amp located in the passanger-side rear cargo area, behind a panel.
Thanks
I just switched out my stock bose system with all the stuff I had from my old car over the period of a couple weeks so I was running the stock speakers off of the new head unit and had no problems at all. I also used one of those $10.00 wire harness adapters, with no problems. Just make sure you hook up the remote turn on because all the speakers have little amplifiers, at least mine did.
atldavek
atldavek
GA
Shugarra
