in reply o not know slew rate DF etc... many people say that anything above 200 is plenty, but one thing i CAN say is that under demanding loads your GOING to hear a difference.. simply put not all amplification is the same.
Both slew rate and damping factor are not "higher is better" specifications. Once the amp has adequate enough slew rate or adequate enough damping to not audibly affect the signal.....that's it. Going higher will not yield audibly different results. And actually, a lot of people suggest that anything above
20 is sufficient for proper damping. See:
Richard Clark
http://www.monstercable.com/mpc/stabletechA2412_Damping_Factor_Article.pdf
"From the damping factor chart it is obvious that the most damping we can expect from our amp/speaker combination is only about two. An amplifier with a damping factor exceeding 10 times this amount is no longer going to play a significant role in this overall calculation. This would yield a practical limit on amplifier damping requirements to about twenty"
Stephen Mantz
http://zedaudiocorp.com/Technical/ZedManual-GREYSCALE.pdf
"We see that the DCR of the speaker swamps all other resistances in the speaker circuit and the .004 ohms amplifier output impedance is almost meaningless. It has been found that a DF of about 20 is quite sufficient to dampen the voltage spikes from the speaker."
Audioholics Article
http://www.audioholics.com/education/amplifier-technology/damping-factor-effects-on-system-response
"All this is well and good, but the argument suggesting that these minute changes may be audible suffers from even more fatal flaws. The differences that we see in Q figures up to the point where the damping factor is less than 10 are far less than the variations seen in normal driver-to-driver parameters in single-lot productions. Even those manufacturers who deliberately sort and match drivers are not likely to match a Q figure to better than 5%, and those numbers will swamp any differences in damping factor greater than 20.
There may be audible differences that are caused by non-zero source resistance. However, this analysis and any mode of measurement and listening demonstrates conclusively that it is not due to the changes in damping the motion of the cone at the point where it's at it's most uncontrolled: system resonances. Even considering the substantially larger response variations resulting from the non-flat impedance vs. frequency function of most loudspeakers, the magnitude of the problem simply is not what is claimed.
Rather, the people advocating the importance of high damping factors must look elsewhere for a culprit: motion control at resonance, or damping, simply fails to explain the claimed differences."
RCs test is impossible to win. because its a totaly fail at what a normal application is..
Then you don't understand the point of the challenge //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
tell me i can't hear adifference under clipping ill tell you ill prove it..
Fine. Go take RC's challenge, prove it to everyone and make yourself $10k richer in the process. I don't see the problem here? The challenge has been open for 10 years.....you've had ample opportunity to go take it. So, what's the hold up?
