BMW 7 series audio install
Thank you and no but as you advised I put dynamat on the rear of the inside.
I was referring to the back side of the kick, not inside of it. I told you to do the more complicated kickfirst. Always do the more complicated side first!!! what if you cant achieve the same angle as the right kick now?
Got the mat laid on the left panel today will sand it bondo and carpet it.
The trunk got wrapped, the top lip where the indent starts will be shaved for the plexi glass. That is why the carpet there is not defined cleanly.
I wish you woulda made thefalse floor a inch or two shorter or cut the sub holes a bit higher so the subs dont look like that, but none the less good work looks clean
bigaudiofanatic
Dynamic Mobile Audio
bigaudiofanatic
Dover DE
bigaudiofanatic
