blown sub?
if u apply some voltage into the coils, and it moves fowards n backwards, does it mean it's not blown? or wat does it actually mean if anythin?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
what would make you think it's blown in the first place.....if it moves freely than no it should be fine...
simple test-------touch a 1.5V battery to it's terminals----------- does the sub move
play a test signal through it --------does it play it clean?
if the sub passes both tests it is most likely fine
i guess by blown i m saying that it used to play fine, but then all of a sudden just stops working. it doesn't play anymore at least in my car. and before they stopped working i didn't hear any pop or anything. i was just playing w a "blown" sub i have and i put a 9v battery actually (instead of 1.5V sorr) and it moves. how can i play a test signal thru it w/o using my HU? like w a cd player or something like that just hooked to the sub or to te amp n the sub.
so if it moves it means it's fine? sorry guys, just trying to absorb ur guys knowledge :p
Originally posted by Matador [ i was just playing w a "blown" sub i have and i put a 9v battery actually (instead of 1.5V sorr) and it moves.
9V is ok------- it moved well least we know the coil still conducts electricity and it no so deformed that it's stuck
how can i play a test signal thru it w/o using my HU? [/b]
take it in [your/someones] house and connect it to the stereo---------you need to see if it makes a [buzzing/scratching] sound when playing----------if not turn up the knob-----see if noise appears
if you sub passes this test------i'd say it's not damaged
though some resistance tests would be nice too
i have a 10'' fat boy sitting in my room, and i also have a sony xplod aluminum something. the sony ***** bad, the fatboy was so much better than the sony.
there's no way to fix them if they blown? like if the VCs are blown or something, can i replace them? from where?
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
931
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
Matador
-= StillBumping =-
Matador
Ca
Matador
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
