I am trying to plug this into winisd but cant figure it out , If anyone can help ? please do! I have about 2cft per box to work with or could do 1 box using same airspace and vent and I have 4 cft inside dimensions to work with , What I need is vent size? , what I should tune it too for the best all around performance ? I listen to everything and am going for sg but still want some spl , (2) 12 inch subs here are the para
HP-1200 12²
VAS:46.9500 ltr
FI:31.113Hz
Fo:31.606Hz
QTS:0.409
QES:0.435
QMS:7.020
Pmx:800.000Wrms
Xmx:13.000 nM
Znom:4Ohm
Revc:3.400 OHm
O.D. 12 1/2"
I.D. 10 15/16"
Depth: 5 7/8"
They will be getting about 600 watts per sub (revolution at 2 ohms) //content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
HP-1200 12²
VAS:46.9500 ltr
FI:31.113Hz
Fo:31.606Hz
QTS:0.409
QES:0.435
QMS:7.020
Pmx:800.000Wrms
Xmx:13.000 nM
Znom:4Ohm
Revc:3.400 OHm
O.D. 12 1/2"
I.D. 10 15/16"
Depth: 5 7/8"
