Blown Mids; Replacement Suggestions
the 8s have less sensitivity than the 6.5s for the neos along with being stamped over cast aluminium, 8s have 1.5 inch coil vs the 2 inch coil for the 6.5s, overall specs is not good compared to the 6.5s so i would not recommend the 8 inch version. There's a reason why the 8s are 30 dollars cheaper than the 6.5s Idk what the fk they were smoking...
How do the 6.5's do in a door? Seems to be right on the line of working well without an actual enclosure.
Will probably crossed at around 70-80 hertz.
not really. i pretty much got what i wanted from the ones you sold me and the ones i have but i'm like you. i'm always open to new ideas.
Yep, it never ends. I just love hearing the tone from different drivers and seeing what they have to offer.
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
931
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
LetMyBeatPound
CarAudio.com Exclusive
LetMyBeatPound
Albuquerque, NM
Jeffdachef
    May 18, 2024
    May 16, 2024
