blown fuses and circuit breaker
Willkas
i had 2 30v fuses in my amp, and im guessing 100amp circuit breaker under the hood. was working normally,
today i saw the fuses were blown, and looked under the hood and also saw that the circuit breaker was blown. how can this happen?
is it possible water could do it because it was raining...........
check your power wire i would think water would do that just make sure that the fuse holder under the hood is fine. when put your power wire in the holder no lose wire should be left for water to get on.
i use a circuit breaker, not a fuse block, the fuse block only holds a regular fuse, the circuit breaker is a big fuse, and the circuit breaker, is blown. the fuse inside which i can see right thru is blown. i hav eno clue how it happened
sorry my bad ok get a fuse holder ditch that breaker of yours lol.
make sure your ground isnt touching your power wire in any possible way or power wire/ chasias... if the main wire is going into the firewall.. make sure the metal hasnt rubbed through the covering of the main wire
water alone doesnt sound like it hsould do this... the problem is somewhere else.. even if the water possibly set it off
not water untless there was a direct flow of current from supply to ground.
It would have had to be sitting in a puddle enough to touch both terminals or there would have had to be a drip of water crossing the terminals. check wires at terminals for frays and what not.
A circuit breaker, that's not a fuse block, that has a fuse?
You obviously dont have a circuit breaker, nor do you know what one is.
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
931
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
Willkas
Willkas
Los Angeles, CA
audioholic
    May 18, 2024
    May 16, 2024
