blown fuses and circuit breaker
Willkas
i had 2 30v fuses in my amp, and im guessing 100amp circuit breaker under the hood. was working normally,
today i saw the fuses were blown, and looked under the hood and also saw that the circuit breaker was blown. how can this happen?
is it possible water could do it because it was raining...........
i use a circuit breaker, not a fuse block, the fuse block only holds a regular fuse, the circuit breaker is a big fuse, and the circuit breaker, is blown. the fuse inside which i can see right thru is blown. i hav eno clue how it happened
make sure your ground isnt touching your power wire in any possible way or power wire/ chasias... if the main wire is going into the firewall.. make sure the metal hasnt rubbed through the covering of the main wire
water alone doesnt sound like it hsould do this... the problem is somewhere else.. even if the water possibly set it off
not water untless there was a direct flow of current from supply to ground.
It would have had to be sitting in a puddle enough to touch both terminals or there would have had to be a drip of water crossing the terminals. check wires at terminals for frays and what not.
A circuit breaker, that's not a fuse block, that has a fuse?
You obviously dont have a circuit breaker, nor do you know what one is.
Willkas
Willkas
Los Angeles, CA
audioholic
BP1Fanatic
    Jun 2, 2026
BP1Fanatic
    Jun 2, 2026
