Bit of help on a new door build
john253a
I'm doing a new build for my doors
And I'm tossing up between 3 setup but learning toward the first 2
What I'm looking at is all by Rockford fosgate
2x t1675 6.75"components @2ohm
1x pp48 8" midbass
In each door on a T800.4
75rms to each t1(150rms per door), and 150 to 8" midbass
Or
3x T1675 @1.33ohm per door
On a t1000.4
Only using 2ch(others used else where)
@ 250rms per door 83rms each t1
Or
2x t2 6.5" components @2ohm on t1000.4
250rms per door 125rms each t1
I see 3 setups? Also, have you purchased equipment and/or are you set on buying RF?
I don't think a 4 channel will like lower than 2 ohms per channel. Is the amp rated for 2 ohms x 4?
the t800.4
150x4@4ohm
150x4@2ohm
200x4@1ohm
the t1000.4
250x4@4, 2 and 1ohm
as for why rf
1 is warranty, and i can claim local and dont have to ship back to usa (costing more the item itself)
2 price, when your dropping 120 just to freight 1 set of speakers, you dont want to be shipping $50 ones
3 price the t1 are on sale for 109us and are 700 over my way
as for what i have the answer is zero, i have nothing
im starting from the start with all new equipment,
and as its in a 4door truck im limited to 0.5gross behind my rear seat for subs
so idd either get the t800.4 and a t500.1, or just the t1000.4
and run 2 sealed 8" behind there
im just trying to get the best front stage i can get as ill have very little bass coming from 2 shallow mount 8" in a tiny box
If you know of something else is the price that will preform better let me now
My other ride has kicker 1x QS65.2 in all 4 doors active on a zx700.5 and zx650.4 (4door truck)
And I want it louder an clearer then that
And that had 2x cvt84 8" and 1x cvt122 12" (8's on zx700.5 and 12 on zx400.1)
So why do you need that much front stage for 2 8" shallow mount subs is my next question? Your mids/highs will easily drown out the subs....
Buy one good set of 2 or 3way comps and be done with it
i like music loud, is one resin
and im not bulding a stage to keep up with anything
the front stage will be everything
the 2 8" are only there to what the front stage can't
i was even thinking of 2x 10" IB in the front door with the 2 comps
but the depth is a problem
john253a
john253a
Austuralia
john253a
