Are you all really this dense? The question isn't whether or not liquid nails or gorilla glue works for an enclosure, it's why the heavenly **** you would even use it? It's over 2x more expensive, less effective and messier. You don't have to preach to me either, as I've used every adhesive in the book before actually testing and reading and realizing that wood glue is the best thing for enclosure bonds. I don't even see why this is a discussion. Also, liquid nails is not a sealant either, it's an adhesive. It doesn't have the properties of a true sealant, which is again cheaper to buy, so why not get it also? If you can't make a good cut, an expanding or ultra-thick adhesive won't help you anyway as it isn't bonding the wood together, it's holding itself in between the spaces in the wood which is just as effective as screws alone (aka weak).
