audioarsonal
JaMarcus
That is after I pre-drill with counter sink I put in a dab of glue.As well as gluing the edges not just glue in the holes sorry.
You NEED to pre-drill w/ MDF... Even when screwing two scrap pieces together... It just doesn't work unless you pre-drill...
Just make draw a line across where that you want all your holes on... Pre-drilling is easier than drilling the screws in...
Wrong. You build shitty boxes if you build em that way. I know thats how I started building em. I finally moved on to wood glue and it makes a world of difference //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifYou can still make a good box by simply using ONLY screws through the entire box.. then sealing all tha edges/corners w/glue.. (Liquid Nails is my preference)
& no, I don't CARE what kind of glue YOU use or what kind of glue YOU think is better. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
All this talk about screws backing themselves out & the bond between the glue & wood breaking.. is bullshit.
You know how hard it is to pull that shit apart? Yeah.. your sub isn't going to do it.
Only thing I've EVER seen like that is a sub backing it's mounting screws out..
Or stratusrt01 had a folded horn that he only used glue & brad nails.. & the side of the compression chamber came off..
I don't build my boxes like that..Wrong. You build shitty boxes if you build em that way. I know thats how I started building em. I finally moved on to wood glue and it makes a world of difference //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sure you can do that, but what's the point?You can still make a good box by simply using ONLY screws through the entire box.. then sealing all tha edges/corners w/glue.. (Liquid Nails is my preference)
It works just fine if you don't predrill. It is just more difficult and more tedious.You NEED to pre-drill w/ MDF... Even when screwing two scrap pieces together... It just doesn't work unless you pre-drill...
Don't ever give advice to this forum on this topic. You are blatantly wrong, and there are published articles by people from woodworkers to materials engineers that state that wood glue is the strongest way to bond wood.You can still make a good box by simply using ONLY screws through the entire box.. then sealing all tha edges/corners w/glue.. (Liquid Nails is my preference)
I guess if you can hold it down... It's hard to be accurate while pushing down with allot of force..It works just fine if you don't predrill. It is just more difficult and more tedious.
