If it was good it would not have smoked the sub. Just sayingThe amp is good, I had my girlfriends dad who used to do competitions install it. A 15 will not fit in my trunk. I'm going to use the enclosure I have so I'm going to get 2 12s.
Thats not how it works. Read the **** tutorial and set it right. Depending on the HU 1/4 could be to much.Could damage have carried over from the previous owner? The gain is now set to 50%, it was around 75% when it went up in smoke. When I bought the system, it was turned all the way up.
JL Audio » header » Support » Tutorials » Tutorial: Input Sensitivity (Gain) SettingCan someone link me to a good gain setting tutorial? I did a search but there are so many different posts about setting gains. Would be much appreciated!
if it is down to those 2 choices SSA Dcon all the way. havent heard the best things about the new RE stuffThe sub was overpowered.Not sure if the enclosure is prefab or custom but the dimensions are 34x16x13. Anything bigger than a 12" is pretty much ruled out since the tiburons trunk is small. I want subs that hit as hard as they can with limited power. I listen to mostly hip hop. Would it be a huge problem to use the same enclosure? I'm a college student on a budget. I can't decide to go with the 12" dcons or 12" re srx's.
