Big 3 upgrade on magnum
  • 5
Should be easy. I've seen the hood popped on some chargers and it looks pretty straight forward from what i can remember.
my car was so easy to do big 3 on. I could have done it in 3rd grade.
Mercury Grand Marquis.
battery to factory ground = 4 inches.
alternator to battery = 1.7feet
engine to factory frame ground = 9 inches
The big three for them goes like this.
1. You usually do Battery positive to alternator, but there's already 1/0 gauge there so there's no reason to upgrade.
2. The battery negative to ground. All you need for this is 12' of good 0/1 wire and a new battery terminal.
3. Shock tower to the bell housing (by the engine bay.) It took me forever to find this, you'll need just 24' of 0/1 gauge wire for this. It's down in a tight space, so patience is important.
When I get all my wires in within the next few days I'm probably going to do a write up over at LXforums.
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
971
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
RT_MAG
RT_MAG
MICHIGAN
RT_MAG
