Better to sacrifice output for upgradability?
maxmil982
I plan on getting an SA12. The basis of my dilemma is whether the sub will be significantly louder and lower powered with 1200w vs 800w?
This is my Orion amp stats:
2400W HCCA High Current Competition Class D Monoblock Amplifier
2400W Class D Mono Amplifier
RMS Power Output:
4 Ohms: 425 watts x 1 chan.
2 Ohms: 800 watts x 1 chan.
1 Ohm: 1200 watts x 1 chan.
My first option is to get the 2ohm and feed it a clean, legit 1200w, matched with o-scope, wired down to 1ohm
Second option is to get the 4ohm give it the lesser 800w @ 2ohm and be better set up to get a second in the distant future and upgrade the amp.
I'm leaning toward second option IF it will be close in loud and lowness to the first option?
If it's not I'd rather have it sounding its best since I won't be upgrading for some time either way.
Thanks in advance
yeah i get it, friend has same problem with his cab amp.. idk what car u got but 1 sa with 1200rms will be pretty loud especially ported.. unless u just chasing #'s (db) u maybe happy with that and if u think u want another one later should be pretty easy to sell your sa with 1200rms so peeps can hear what it can do..
9512 lol If you're in that realm of woofers, there's quite a good selection outside of those 2, but DD is a very good pick IMO.
2.5 cubic feet per subwoofer not total. Those X's require some room.
787
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
Alpine, and it's not even close. I own that Alpine unit and the 9-band parametric EQ is much more useful than the 5-band graphic on the...
maxmil982
maxmil982
Atlanta, Ga
BOOMINGRANDPA
audiobaun
    May 19, 2024
    May 19, 2024
