Better to move the box up front?
Not too sure on the quality or longevity of a DB Electrical alt, but it really sounds like an alt problem to me. You should google the error code you got and see what shows up...
Could also be one of your batts though...
Do you have a DMM to test your stuff? It'd be a good way to see where your voltage and everything is at with the car running, with the car off, and blasting your system.
I'll have to check those kicks out..need to fix my emissions problem though first //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
voltage stays on 14.4 with car running, i can check when it's off but im pretty sure it stays on 14.4. drops slowly down to 10-12ish on high vol.
i have already checked the codes, asked them before on this forum but couldnt get a solution. high current and ELD are the same codes everytime.
Hmmm...would say maybe one of your batts are jacked up then.
I tried googling your errors, and those seem totally unrelated to your audio situation //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Is there anywhere you can get your batteries tested or something?
i could at autozone when i separate both batteries
I think that's your best bet...maybe someone else will chime in that has some more knowledge about running multiple batteries. Maybe autozone could test your alternator too...I know when alts get hot, they generally don't put out as much as when they're cool...maybe autozone could test this for ya.
Wish you the best of luck...sorry I couldn't be more help!!!
it's cool, thanks for the help though.
sometimes my sub would stop then come back on. weird haha
Maybe your amp is going into protect when the voltage gets too low? You should play it safe till you can get your stuff checked out...uhg, 6:36am...time for bed
plyer3
plyer3
N Little Rock, AR
Boomintempo
