Better than Hifonics Brutus 2100?
im looking at it now. but it says 2600 watts at .5 ohms. and 1670 and 1 ohm. my subs are 1000 watts each rms dual voice 4 ohms. how will the wiring work? im not tryna go rediculous and spend hundreds upgrading the electrical in my car too lol
it is nice when a manufacturer will state their amps are .5 ohm stable and show a max output..It gives you a good idea of the build quality and available headroom(combined with other specs)..The total stated rms power available on this amp is 3500 watts, 400 dampening factor @20hz, .1% THD at rated power (prolly 4 ohms)..frequency response down to 15hz..these are much better specs than what has been mentioned thus far. Your subs would be wired down to 1 ohm. The specs indicate you will have available headroom for transient peaks, good cone control and response all the way down below usable frequencies and far less distortion at 1ohm. I cannot tell you exactly what power each sub will receive wired parallel due to ohm rise, signal input (what song), etc. will it be adequate for your two subs and electrical? as much or more than anything mentioned here thus far.
I would recommend nailing down the problem you had with the last 2 amps before buying anything though, to be honest.
no clue lol....
the other precision power amp didnt give any sound out frm the speaker terminals so thats why i got the hifonics one. same problem with hifonics except this time i think i smelled it burn somehow so no idea. i have to see if it was the amp somehow. if it doesnt work with my replacement hifonics im getting a new company. probably the lanzar or AQ
If two brand new amps didnt work.. I would highly doubt it's the amps fault. Most likely a wiring issue (considering you were asking what ohms you would be running, points towards user wiring error)
if it comes with a warranty, I wouldn't be worried. I see people saying all the time how they are sketched out by ebay stuff then they go on and post their own audio stuff on their. Hello, irony?
"If you are dissatisfied with your purchase for any reason within the first 30 days just send back the product and you will receive a full refund with no questions asked. If you have any problems with your product within the first 60 days just send back the product and we will send out a replacement for no charge."
better than what?..lol..Maybe step it up to the AB HD3500..and then u will be close.
than the hifonics. those ab phantoms are the bomb. ive installed a few just straight swaps from a brz1700 and they are all doing better. cleaner sounding and most gained on the meter too
im at a 46 now on 2k he was doing something wrong! lol
that was straight stock battery and a small 1200 power cell. That was also metered with brand new fresh out of the box subs before they were worn in. With my 150.1 I can burp 146.7 on those same xfl's without having it at full tune volume
RoYALbLUE08
RoYALbLUE08
NYC
Jaguar
