Better: Eclipse SW9122 or Eclipse SW8200 ?
The 9122 will be louder, the 8200 will sound better.
So if I want more bass, the sw9122 and if I want quality, the 8200 ? I had an sw9122 before and it pounded. What amp would you match either of these up to to make it sound perfect ?
Personally, I'm more about SQ than loudness, so I would recommend the 8200. I've got one that I used for a year, and now going to be using it in HT.
Depends on your budget for the amp. Easiest and cheapest way to get the power to the 8200 is to buy a 2 ch amp that does ~700w bridged @ 4. (Since its a SVC 4 ohm sub)
You'll have more options for an amp with the DVC 9122.
What is HT ? Why wouldn't I want more power than 750w for the sub ?
Ok, now another question, are Blaupunkt amps any good ? I am getting a full eclipse set-up and was lookign at their amps. The guy I am buying from told me he had them at a good deal.
3 cu sealed would be nice for a pair of 8200's. I had mine in a 1 cube, and it had a peak in the response curve, with little low end (LOW low end).
increasing to 1.5 each would prob be very nice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
kasimo420
kasimo420
Portsmouth, VA
dragnix
