Can the BEtter Audio 1600M1/RE 35.1 run 0.5 for daily? I run a single RE SX 15" but want to add a second. The amp has two outputs but I do believe they are wired internally parallel so even if each sub was conneted to the amp for a 1ohm load on each output the amp would still be seeing 0.5ohm correct? Just wondering if it will run daily ok if it is not abused, no more than 1/2volume or possibly set the gains lower except for comps. The amp does have extra cooling. I added two fans for a crossflow effect.
