Best way to be safe
I always feel if you can get volumes in excess of anything you ever want to listen to at the higher impedance, go with it. If you can only get to the volume you want by running at the lower impedance (and the amp/system can handle it), then you gotta do that! It’s all relative.
I have a DD1. In hindsight, I never should have bought it. They work for what they do, but what they do is test voltage up to 1% THD. If you want to see what you can max out your amps, at 1% so that you can get subs for that wattage, then okay cool, your DD1 comes in handy.
Personally I found more use out of it seeing what voltage my head unit puts out at what volume, (Kenwoods seem to be at the rated voltage at 34 out of 35, and extra 10% at 35).
If you know what wattage you want, then use this method:
Do some quick easy math, use any multimeter and set it to AC voltage.
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
audiobaun
