Best tweeters for around $150max (opinions)
  • 4
Your head unit is 100x more important when it comes to taming tweeters then the actual tweeter brand itself.
I currently run a Kenwood ddx 471, what hu would you recommend if that hu is not sufficient for decent to good non bright output for tweeters?
Where are you mounting the tweeters ...location is very important
Hmm I didn't think that would cause brightness just slight distortion. But in the door panel stock position of a 2012 ford focus sedan se. Do they make after market mounts? Or is anyone on here selling custom mounts?
Infinity kappa 62.9i in front and 63.9i in back, often turn off the 63s, the kappa are co axis and the tweeters r quite underwhelming so it issnt those causing the main tweeters to sound bright, and the brightness issnt there when the main tweeters are disconnected
Sorry I didn't quote you, see post above this one please
So your door originally had the Ford mid tweeter combo and you replaced it out with the infinity speakers but the tweeters seem extremely and bright in the Infinity set ..an over powering brightness ..am I correct on this from what I’ve gathered ?
I was looking up your car and speakers trying to figure out the setup ..I have a 2005 Steeda Focus but it’s made entirely different
It's located above the door inbtwn the door window and the windshield it's behind the black triangle plastic piece
Piezo tweeters. The really inexpensive ones. The number of people whom have been looking for just a little improvement on a budget. The smile...
That's what I was thinking of running at 16 gauge thank you.
29
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
394
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
516
grantking2256
Waco, Tx
Jeffdachef
    May 24, 2024
