Best place to buy bank o caps?
  • 5
will do, itll be a while though. if i get familiar with solidworks ill see if i can make a model or something
You use solidworks??? I literally just turned in a solidworks assignment at 1:00 this morning.
Some times I feel like google sketchup is better, but there are better technical features in solidworks.
There's a machine shop on campus I'll have access to in a year or two. You can submit CAD files and they'll make the parts for you at cost. I take a class later on where we do prototyping.
i havent had time to learn it but if its anything like sketch up it'll be easy. i have a coworker that works with it pretty regularly
ill ask my coworker if alumni have access to the service
I takes some getting used to. It's not like sketchup at all //content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif
Not even close....... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
i don't think it's as hard as you think lol its not like ive never looked at it i just havent designed anything in it
You have to select a plane for each edit. Your addition can't leave the plane. You have to create a "new sketch" every time you don't want something to be joined by code. If you don't and you mess up one small piece, you have to delete the whole "sketch". Manipulating the viewing angle is stupidly complicated and touchy. You have to "define" a certain amount of measured values on each figure, but you can't define too many. Otherwise you'll get an "undefined" or "overdefined" error. Also, you can set the dimensions of a shape, and the program will change them to "help fit" if you draw something else similar in the same file. Or if two things are touching and not "fully defined", they'll both get fucked up if the program tries to auto fit anything else. Also, once you save it won't let you undo anything. Let me know what you think.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
295
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
468
I hear ya. There are so many good deals on speakers too. My kid is 16, so loud is better than SQ. LOL... I really like the sound of the PPI...
15
791
818
My63bug
My63bug
Vacaville ca
adulbrich
    May 20, 2024
    May 20, 2024
