best hu 4 maxima
  • 2
doesn't matter too much which HU u choose, it all comes down to peronsal preferance
i recommend clarion, but check out all kinds!
i assume you have 2 tweets and 4 woofers..
as long as you have x-over you can...
an easy way to figure it out is to look at the back of your stock deck and see if there are 4 or 6 speaker wires.
just make sure that there aren't any factory amps in line from the HU...//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
sounds like you're gonna have to, unless there are crossovers
you might wanna invest in 1 set of x-overs, would be well worth it SQ wise!
x-overs split the sound between the tweeter and woofer, sending the tweet high freq. sounds and the woofer mid-range freqs. get one that you can adjust, cause you'll want to play with it. you'd want one anyways, cause the HU sends all the freqs. to all the speakers (assuming you dont use an amp.)
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
401
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
521
I hear ya. There are so many good deals on speakers too. My kid is 16, so loud is better than SQ. LOL... I really like the sound of the PPI...
15
911
865
slick rick
OG
slick rick
Violates Miranda
budgetSQ
    May 24, 2024
