best hu 4 maxima
i assume you have 2 tweets and 4 woofers..
as long as you have x-over you can...
an easy way to figure it out is to look at the back of your stock deck and see if there are 4 or 6 speaker wires.
just make sure that there aren't any factory amps in line from the HU...//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
sounds like you're gonna have to, unless there are crossovers
you might wanna invest in 1 set of x-overs, would be well worth it SQ wise!
x-overs split the sound between the tweeter and woofer, sending the tweet high freq. sounds and the woofer mid-range freqs. get one that you can adjust, cause you'll want to play with it. you'd want one anyways, cause the HU sends all the freqs. to all the speakers (assuming you dont use an amp.)
slick rick
OG
slick rick
Violates Miranda
budgetSQ
NorthFramingham
    Jun 30, 2026
