best hu 4 maxima
  • 2
doesn't matter too much which HU u choose, it all comes down to peronsal preferance
i recommend clarion, but check out all kinds!
i assume you have 2 tweets and 4 woofers..
as long as you have x-over you can...
an easy way to figure it out is to look at the back of your stock deck and see if there are 4 or 6 speaker wires.
just make sure that there aren't any factory amps in line from the HU...//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
sounds like you're gonna have to, unless there are crossovers
you might wanna invest in 1 set of x-overs, would be well worth it SQ wise!
x-overs split the sound between the tweeter and woofer, sending the tweet high freq. sounds and the woofer mid-range freqs. get one that you can adjust, cause you'll want to play with it. you'd want one anyways, cause the HU sends all the freqs. to all the speakers (assuming you dont use an amp.)
Ohhh i see its a depth issue, so i should be good with ordering those spacers bet ill order them and hopefully they will work out fine, thanks...
45
I had an older version for a year. I just bought the newer version 2 months ago and it was better. The touchscreen works very good for a cheap...
6
223
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
658
slick rick
OG
slick rick
Violates Miranda
budgetSQ
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
