best box for 4 12s
i3abyjay25
Get F'n Loud
i need the best box set up for 4 12 kicker xpls.. my trunk is 36x33x14.. so i guess the largest box should be about 34.5 x 31.5 x 12.5 if useing 3/4 mdf (inside of the box) but thats what about 1.9 cubes per sub.. is that to big? .. and 35x32x13 useing 1/2 inch, whic would about 2.1.. the box i have now is made of 1/2 and its holden up pretty well.. thans to alot of fiberglass to seal it.. the subs requirment asks for 1.0 to 1.5 cubes.. so whats the best box i could build, and which way do i need to face the subs.. all 4 will not fit all the way across the fron wall, unless if i modify the box.. but ill be loosen alot of space..the box now is, 36x331/2x10 (outside of box) and all 4 subs are faceing upwards.. its 2 chambered which should be abot 2.96 per chamber.. which i guess u can say 1.43 to each sub... .. **** i forgot the formula, is it LxWxH / 1726, or 1728? i was useing 1728.. but am thinking its 1726? o well, any help would be greatful.. and if u modify the front face, please try to make a picture for me
like the design of this.. all 4 faceing front, and hittin the same spot on the trunk.. not a perfect drawin, just an idea.. only prob is.. loss of a lot of space.. still trying to figure out the volume of this 1...
Here try this,..the area of a triangle is 1/2 Base times Height so you can figure out how big each is. Then use that figure w/the other measurements to get the volume.
ok, thanx for the info, but im still confused.. all i know is LxWxH is volume of a box.. what would base be? or see if u can figure it out for me.. if it was a full box, it would be 36 x 33 x 14... but its not a full box..
i have a 2002 montecarlo i had a shop build me a box for 4 12compvrs okay two of them face up under the rear speakers i put mid and tweets instead of 6x9 i also dynomated the deck to deflect the signal . okay back to box it measures 33 1/2 x w/26 1/2 d x 14h so in the top are 2 and the front are 2 firing in the rear of car trunk whats the volume dont know with there new db machine i hit 131.9 dbs i know it hits harder they just didnt know how to do it right.
yeah w/ 4 12s, u should be hittin alot harder.. w/ my epic 150, i gotton up to 151.. and that was the 1st day i got it.. i havent messed around w/ a the settings or even turne the bass up.. i have always kept bass on 0.. on the (HU) and my amp isnt turn up but about half way..and w/ my stock 70 amp alt.. i now have 175 bt havent really played around.. i really dont want o blow my subs.. i know i want new 1s, but i dont have the money from them now..and at 151.. i dont really want to jus waste them..
So I don't know what i'm doing but I really like the used H-KO but when i look at the specs it looks like it could overpower the sub if I'm...
19
I think he wants to use the existing enclosure he has, and its cut out for a single Ten inch sub at the moment
19
3K
This $100 over your budget but it checks every other box https://stereointegrity.com/product/bm-11/
10
A $200 budget is do-able but a little tight for certain features wanted verses needed, and will take a search to find what you want. Id deff look...
38
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
631
i3abyjay25
Get F'n Loud
i3abyjay25
Dallas, Georgia
i3abyjay25
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
