best 12'' subwoofer for up to 400w RMS???
Wanting to run 1 12'' sub in a ported enclosure. My amplifier (Crossfire CFA 402) is rated @ 400w RMS x 1 @ 4ohm.
In your opinion, what is the best subwoofer for my application?
I've been looking into the Mmats Pro Audio P2.0 & P2.5, as well as the SSA Dcon 12.
Any other suggestions?
Rather than create a new thread, I figured I'd bump this. I'm looking for a budget 12" sub that will be powered by a PPI 460iqx (4x60, 2x200) with an emphasis on being able to play low in a vented enclosure. Overall output isn't of real concern as my previous sub was a 10w3 wired to 8 ohms so the doubled power of a 4 ohm load + more cone area will be enough for now.
I've been plugging t-s params in ISD but it's a really sluggish process because they aren't readily available. After reading the responses here, I figure at least a couple of you might know off-hand a decent priced sub that can play low in a reasonable enclosure. I have up to ~3.5 cu/ft I'm willing to allocate to the box.
I guess budget would be in the $50-60 range, but if there exists no such sub that will sound good in a reasonable sized box tuned reasonably low (~25-30hz?) then suggest something more expensive.
Bob Saget
Banned
Bob Saget
Seattle, WA
Smasher
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
