Best 10" Sub ???
My boy has 2 12w6v2's firing down in the rear of his escalade. You can definitely fit two twelves back there. Another friend has 2- 12w7's w/ 2- 750/1's behind his third row of a denali 1 sub on each side with the port facing up. Forget the tens and get a pair of twelves back there.
Also a single xcon 12 w/1500rms in the right box will definitely do the task.
Any recommendations for a 15 then?
Audiopulse Axis (or LMS 5400). Either perform well in small-ish box tuned low. As someone else said the TC 3hp motor is a great platform to build from. pretty much anything built on that motor would be great.
SSA Xcon is another nice sounding sub that'll get loud.
A pair of 12s will not fit. I'm gonna be pushing it for just a pair of 10s.
Here's a view of the space.
Can you show a picture of how they fit or something, please?
So far leaning towered the fi bl10.
If I do get these are these all the correct options I should have for say 2500-3000wrms for both subs?
Not pullin the trigger till sat so I'm still open to other ideas/options.
find a pair of 3hp motors and i can build you some sick subs that will handle 2500rms each no probs...
Strongly considering your offer. I would be able to throw both the bpx2200.1 amps I have just sitting around. I bought them a while back as they give out excellent power at 4 Ohms, dont see that often enough.
1) how much if you were to build a pair for me?
2) What would be the turn around time?
3) any warranty/support available?
4) Finally, how would I get the needed TS parameters needed for designing the box and would these subs be suited for a tuning around say 33Hz ported box?
Strongly considering your offer. I would be able to throw both the bpx2200.1 amps I have just sitting around. I bought them a while back as they give out excellent power at 4 Ohms, dont see that often enough. 1) how much if you were to build a pair for me?
Private message him
post up your dimensions and I will see what works best for your cabin
I need:
height to seat level
max width for box
max depth for box at seat top and seat bottom
base of windshield to base of gate window
with out knowing exactly how your cabin reacts and exactly how much space you have all people can do (and have been) is guess.
Just using what I know from my suv with 3 rows 2 10's in a horn will work rather well
murtnabila
murtnabila
Sacramento
LosIsATool
