Battery
i have ,if they are both agm ,then its ok to run both
Yellow Top Specs
attery Type: Sprial AGM
BCI Group Size: D34/78
Cold Cranking Amps: 750 amps
Cranking Amps: 870 amps
Deep Cycle/Starting: Deep Cycle
Height: 7 13/16 in
Length: 10 in
Maintenance Free: Yes
Reserve Capacity: 120 min
Terminal Type: Dual Terminal
Voltage: 12 v
Weight: 46 lbs
Width: 6 7/8 in
Main Question is should I run the BT up front or in the trunk... or would running the BT by itself if i'm not pushing more than 1500 watts..
cyn
cyn
Orange, Texas
NASTY08IMPALA
